		 looking at the **O/D** light just under the cluster/globe.
 continuous blinking = normal. no defects.
 code #42, 4 blinks followed by 2 blinks = Defective No. 1 vehicle speed sensor (in combination meter)  severed wire harness or short circuit
 code #61, 6 followed by 1 blink = Defective No.2 vehicle speed sensor (in ATM)  severed wire harness or short circuit
 code #62, 6 by 2 blinks = Severed No. 1 solenoid or short circuit  severed wire harness or short circuit
 code #63, 6 by 3 = Severed No.2 solenoid or short circuit  severed wire harness or short circuit
 code #64, 6 by 4 = Severed lockup solenoid or short circuit  severed wire harness or short circuit
 HINT: If codes 62, 63, or 64 appear, there is an
 electrical malfunction in the solenoid.
 Causes due to mechanical failure, such as a stuck
 valve, will not appear.
62 Solenoid หรือ ชุดสายไฟมีปัญหา แบบนี้เกียร์เปลี่ยนครบเหรอครับ ถ้ายังเปลี่ยนครบก็ยังใช้ได้ แต่ดูแล้วน่ะจะเปลี่ยนไม่ครบ ดูกล่องด้วยนะ c เยิ้มป่าว
				แมน, JZM-112
