24-06-2008, 09:46
#2
วันที่สมัคร: Apr 2008
กระทู้: 8
กระทู้ต้นฉบับโดยคุณ oat
1.) Red - Constant 12v
This wire hooks to the beefy red wire coming out of the switch. There are actually 2, and I found it didn't matter which one you chose, both are constant 12v
2.) Blue - Accessory Wire (Becomes active when switch is in #2 position)
Big Orange wire
3.) Yellow - On Wire (Switch in # 3 position)
Big Blue wire
4.) Black - Ground
Since I put my controller in the center console next to the lighter, I mounted it to a metal post inside.
5.) white - break
ขอบคุณมากๆเลยคร้าบบบบบบบ
