เก่า 29-04-2008, 11:28   #16
najake@lampang
รูปส่วนตัว najake@lampang
Car Brand: X
Engine Type: Mid night racing
ที่อยู่: LAMPANG
อายุ: 54
กระทู้: 354
คะแนน: 19 najake@lampang is on a distinguished road
13 G, NE Signalญ (No. 2) No NE signal to ECM for 0.1 sec. or more at 1,000 rpm or more.ญ Open or short in crankshaft position sensor circuit.
Crankshaft position sensor
ECM
NE signal does not pulse 12 times to ECM during the interval between G1 and G2 pulses.ญ Open or short in crankshaft position sensor circuit.
Mechanical system malfunction (skipping teeth of timing belt, belt stretched)
ECM
Deviation in G (G1, G2) and NE signal continues for 3 sec. during idling (throttle fully closed) after engine warmed up. Mechanical system malfunction (skipping teeth of timing belt, belt stretched)
Camshaft position sensor No. 1, No. 2
ECM
อ่านเล่น ๆ ดูครับ
najake@lampang is offline   ตอบพร้อมอ้างถึงข้อความเดิม
